2001 Dodge Caravan Jerk Motion upon release
10,300 MILES • 6 CYL • FWD • AUTOMATIC
NEEDANSWERS959
Sometimes when I release the parking brake pedal and put the gear in drive or reverse, my car seems to be locked up. I have to put pressure on the gas pedal and the car will then make a loud thug or bang-like noise and jerk upon release.
Apr 3, 2009 at 8:34 AM
  • 110,246 POSTS
Does thisonly happen when you use the park brake?
Apr 6, 2009 at 4:50 AM
NEEDANSWERS959
Yes. The only time. Iniitially I was parkiing on an incline. Also, I was pushing down the park pedal too hard. Since I stop doing that it has only happened once.
Apr 6, 2009 at 10:57 AM
  • 110,246 POSTS
Hi:
It sounds like the park brake is sticking. There are steel cables under the vehicle. Make sure they are not rusted. Also, oil them. Also, make sure the brakes are clean inside the drum. Sometimes too much corrosion, brake dust... can cause the shoes to stick.
Let me know if this helps.
Apr 7, 2009 at 3:42 AM
