2001 Dodge Caravan Interittent P0401 code
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALEXV55
  • 51 POSTS
I get intermittent P401 on my grand caravan (flex fuel). It comes on then in a day or two disappears.
Other symptoms are erratic idling, which seems to be increasing. I have read other posts that changing egr didn't solve their problem. One posts suggested changing egr solenoid, but I couldn't purchase solenoid anywhere. Is it part of egr.
Nov 4, 2010 at 8:25 AM
SATURNTECH9
  • 30,869 POSTS
Look's like the solenoid does come with the egr valve i found it for 64 plus shipping.Before you start changing thing's i would make sure you have a good vacuum source to the solenoid and all the hose's are good.Also that egr valve hold's vacuum and doesn't stick open.Also that your egr port is clear.
Nov 4, 2010 at 9:01 AM
