2001 Dodge Caravan Injector #6 not operating
133,000 MILES • 6 CYL • FWD • AUTOMATIC
BEV238
Hooked noid lite to #6 and lite stays on - Thought it was a computer problem - Changed out computer and lite is still on
I drove Van from Indy to Cincy, worked great, drove around some and went to restaurant, when I left restaurant, it ran horrible, white smoke and gas coming from exhaust
Aug 24, 2010 at 7:57 AM
LEGITIMATE007
  • 5,121 POSTS
hi, sounds like it needs replacement, its intermittent but is only going to get worse, when the vehicle was blowing all of the smoke, that was because it was stuck open(not seated) and was dumping fuel into the combustion chamber causing a "rich" condition, before replacing, just check its wiring for trouble.
Aug 24, 2010 at 8:09 AM
BEV238
Wire is unplugged from injector, noid lite plugged into injector wire - Lite stays on extremely bright
Aug 24, 2010 at 8:15 AM
LEGITIMATE007
  • 5,121 POSTS
ok then that would have something to do with the wiring, or the drivers inside the ecm(computer)
Aug 24, 2010 at 8:22 AM
