The problem popped up about a week ago. In time sequence, at Key ON I can hear the fuel pump run for approx 2 secs and then turn off. The engine turns just fine but often the engine will not fire even after 3-5 attempts. When it does start it runs rough for 5-10 seconds and then the idle evens out. I put dry-gas in the tank to remove any water since we had a cold spell when this problem showed up. I do not see a Check Engine Light which would suggest a fault somewhere.
Suggestions ??
Thanks,
Jim
Suggestions ??
Thanks,
Jim
Dec 17, 2009 at 10:48 AM
