the gauge lights are out and the tach is inop. Where are the fuses for these components?
Apr 2, 2010 at 12:06 AM
CH112063
✓Experienced Mechanic
It is located in the engine compartment in the front left side. The power distribution center. It has a lid on it identifying each fuse. The cluster is fuse 24 a 20 amp fuse, see if it helps, ok
Apr 2, 2010 at 12:50 PM
MATTVANDELAC
MEMBER
After asking a variety of sources, I tried disconnecting the battery and touching the cables together for a few seconds, they worked!
