2001 Dodge Caravan fuel tank filler neck
11,100 MILES • 6 CYL • FWD • AUTOMATIC
F37WN0
hello, I am in a position where I am going to have to change the fuel filler neck (tube), and was wondering if there is any how to articles out there? Looking at the vehicle, it does look pretty straight forward, but not sure if there is any special tools I might need, or any certain steps I will need to follow.
Thank you
Nov 11, 2008 at 3:22 AM
F37WN0
I did change the neck last night, and the one thing I will strongly sugeest, is to take off the inner wheel well plastic liner, it will make life so much easier for you. After you take off the liner, it is pretty straight forward, You don't even need any special tools, just squeeze the tabs on the tube ends, and they will pull off. My one suggestion is that after you install the neck, spray the who;e thing down with undercoating, this will slow down any future rust, and hopefully keep you from having to do this again.
Nov 12, 2008 at 12:30 AM
