2001 Dodge Caravan Fan, Wiper, Radio failure
200,000 MILES • 6 CYL • FWD • AUTOMATIC
ADRIANBROOKES
When I switch to the RUN position, everything works, when I START the car, the wipers, fan and radio go off, when I switch off and put key back to RUN position, everything works again.
This happens 90%. Other 10% when I start everything is ok, but may fail while driving.
Hard to drive in snow without wipers/heater fan!!
THANKS
Dec 19, 2007 at 1:04 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the ignition switch has a bad spot in it. Can you make things work by wiggling the key? Have replaced many Dodge ignition switches for just such complaints
Dec 19, 2007 at 4:26 AM
ADRIANBROOKES
Thanks for the reply! I've tried wiggling the key while its in the RUN position but those electircs don't come back on. Was hoping it might be a relay but will try to look at ignition switch a littel closer.
Thank you for the thoughts!
Adrian
Dec 19, 2007 at 4:39 AM
