Our Grand Caravan has a 3.3L engine. The check engine light was on intermittently and the dealer said it was due to the thermostat not controlling. I flushed the radiator and replaced the thermostat. It is still running hotter than normal (needle in the middle of the gauge when its normally at 1/3). At about 80,000 miles it did the same thing and the transmission ended up failing (torque converter). Although the engine light is not on I think I still have a problem. What else can it be? Water pump (what would the symptoms be)? The transmission again? Any suggestions you might have would be appreciated.
Mar 12, 2009 at 5:06 AM
