[quote:659b0aeb97="plumzell"]Engine Mechanical problem
2001 Dodge Caravan 4 cyl Two Wheel Drive Automatic 140000 miles
my 2001 dodge caravan stolled while i was driving and now it won't start[/quote:659b0aeb97]
Sounds like what my 94 did to me. In that case it was the fuel pump. sometimes by pounding on the gas tank you can get it to start but it is only a band aid to get it home or to the shop. When you turn the key to on listen for the hum of the fuel pump or check using a fuel pressure tester.
Jan 11, 2010 at 6:31 PM
