2001 Dodge Caravan ENGINE NOISE
126,000 MILES • 6 CYL • FWD • AUTOMATIC
JUAN GAVIRIA
My minivan is making a sound from the belt side passenger side, everything looks good on that side. the noise comes from inside of the engine is like "gears running without grease" and I am not sure if is the timing chain
Jun 12, 2010 at 6:35 AM
  • 110,246 POSTS
Have the water pump checked. If you want to do it yourself, remove the serp belt and start the engine to see if the sound is gone. NOTE: DO NOT run the engine more than a few seconds to determine if the sound is gone. It will overheat.
Jun 14, 2010 at 4:58 AM
