2001 Dodge Caravan drive belt
2001 DODGE CARAVAN
ROBERT LYDIC
Engine Mechanical problem
2001 Dodge Caravan 4 cyl Two Wheel Drive Automatic
how to change a drive belt
Nov 21, 2009 at 9:57 AM
CH112063
  • 1,320 POSTS
If you have tools, it depends on exactly which belt. The tensioner holds one in place. And the other is used for the power steering. Loosen the power steering pump hold down bolts to release tension, and the tensioner pulley is moved to remove the other belt. A belt routing diagram is found under the 'site map' section. To the lower left.
Chrysler recommends a DRBIII to check the belt tension on it's scope, and you will need a hoist, for shield and screw removal. Two belts. If you have trouble, please just ask. Disconnect the battery before any service. ok its not too bad.
Nov 23, 2009 at 9:11 PM
