2001 Dodge Caravan 6 cyl Front Wheel Drive Automatic
My check engine light came on in my caravan. I did the self diagnostic test and the only code that came up was E. What does it mean?
Sunday, July 6th, 2008 AT 12:49 PM
BMRFIXIT
MECHANIC
I m not familiar with E code on caravan
but I know if you cycle the ignition key on off three times you can read the codes in the odometer area
(p0000) and then it should read DONE
good luck
