SPEEDOMETER, GAS GAUGE. RPM AMD GEAR LIGHTS STOPPED REGISTERING ALL OF A SUDDEN WHAT HAPPENED HOW DO I FIX IT...
Jun 7, 2008 at 3:57 PM
BMRFIXIT
✓Experienced Mechanic
1st step is check all fuses
with the key on and engine running use a volt meter and or test light check fuses
replace as needed
2nd try to get the code s
Body control module need to be tested for codes
