2001 Dodge Caravan DASH BOARD
57,000 MILES • 6 CYL • FWD • AUTOMATIC
WESLEY TRIBBLE
THE SPEEDOMETER, GAS GAUGE,RPM AND THE PART THAT SHOWS GEAR THAT VEH IS IN STOPED REGERSTERING UNABLE TO TELL FUEL LEVEL SPEED OR RPM OR WHAT GEAR VEH IS IN PLEAS ADVISE THE THE PROBLEM COULD BE JUST STOPPED WORKING.
Jun 7, 2008 at 3:50 PM
BMRFIXIT
  • 19,053 POSTS
Possibilities
1. fuses
2. BCM need to be reprogram
3. bad cluster
4. wiring short or open
5. check fuses and if all ok try and get the codes make sure you get BCM scanned for codes too
6. OBDII reader will not give you the BCM code you need a scanner
Jun 8, 2008 at 12:08 AM
