CODE P0508
CASILLAS
6 cyl Front Wheel Drive Automatic. I need to know how fix code p0508
Nov 16, 2008 at 8:57 AM
ZACKMAN
  • 4,202 POSTS
DTC P0508: Idle Air Control Circuit Low. It sounds like the IAC valve has gone bad and need to be replaced here is a guide to show you what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Here is how it will be on your car. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
Nov 16, 2008 at 4:14 PM
