2001 Dodge Caravan All Dashboard Gauges and Turn Indicators
99,000 MILES • 6 CYL • FWD • AUTOMATIC
HOMETOWNGIRL54
My husband was driving and all of a sudden all the gauges went all the way over to the far side and then came back and went way below 0. Now none of the gauges on the dashboard work or the turn indicators. Van seems to run fine otherwise. Is it something my husband can fix? We are on a limited income. Please Help!!!
May 17, 2008 at 4:17 PM
LEGITIMATE007
  • 5,121 POSTS
sounds like there may be a short in the body control module , its halfway behind the center pillar and driverside dash. but just to be certain that your not doing more than you have to. check all fuses under the dash and inside engine compartment. because alot of the electronics in vehicles have several components on one ground, so if something else goes bad, it can effect other components and cause them not to work, so look for other things too, thats not working all of a sudden
May 17, 2008 at 5:19 PM
