2001 Dodge Caravan Airbag Light
101,000 MILES • 6 CYL • FWD • AUTOMATIC
I have a 2001 Dodge Grand Caravan loaded with everything. The airbag light is on most of the time. It may go off momentarily but not for a long time. The horn and cruise work when it is lit and my regular scanner does not show a code. (I don't know if there is a separate means of scanning the a/b for codes). I have read about the clocksprings going bad, but with the other two symptoms, so I don't know if I have something different.
Thanks,
B
Oct 15, 2008 at 9:26 AM
BMRFIXIT
  • 19,053 POSTS
OBDII reader will not read AIR BAG codes
u need a scanner to do so
very common is the clock springs
and if you call your local dealer with the vin # they should be able to help you if its covered under the recall
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 15, 2008 at 9:41 AM
