2001 Dodge Caravan a/c
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRANCODEF
my a/c work fine at high fan ventilation only, when i turn the knob a the lower speed no air ventilation.
can you suggest to chance all the a/c control panel or just the knob.
thank you
Mar 25, 2010 at 6:49 AM
OBXAUTOMEDIC
  • 3,715 POSTS
Since it works on high and not any other setting the most common cause is the Blower Motor Resistor which I believe is mounted in the duct work under the passenger side near the blower motor.
Here are a couple pics of the resistor...
Mar 25, 2010 at 7:38 AM
