SHIFT QUALITY QUICK-LEARN PROCEDURE
1.Shift quality quick-learn procedure must be performed to provide proper transaxle operation if any of the following have been done:
ï¬ Vehicle battery was disconnected.
ï¬ Transaxle assembly was replaced.
ï¬ TCM was replaced.
ï¬ Solenoid assembly was replaced.
ï¬ Valve body was reconditioned or replaced. 2.Shift quality quick-learn procedure must be performed using Chrysler's Diagnostic Readout Box (DRB-III) scan tool. The following conditions must be met when performing shift quality quick-learn procedure:
ï¬ Brakes must be applied.
ï¬ Engine speed must be greater than 500 RPM.
ï¬ TP sensor angle must be less than 3 degrees.
ï¬ Shift lever must remain in designated position until prompted to shift to overdrive.
ï¬ Shift lever must remain in overdrive after the shift to overdrive until scan tool indicates procedure is complete.
ï¬ Calculated oil temperature must be 60-200°F (16-93°C). 3.Connect scan tool to DLC located below driver's side of instrument panel. 4.Using scan tool, select TRANSMISSION, MISCELLANEOUS, then QUICK LEARN PROCEDURE. Follow instructions displayed on scan tool to perform shift quality quick-learn procedure. Remove scan tool.
Apr 2, 2009 at 2:22 PM
