2001 Dodge Caravan
155,000 MILES • 6 CYL • FWD • AUTOMATIC
ANTHONY.BACA1
My vehicle will not shift out of gear going down the road. I have replaced the input and output sensors, I also changed the filter and fluid but is still does not shift. reverse and drive work fine.
Jan 7, 2008 at 1:27 PM
BMRFIXIT
  • 19,053 POSTS
[quote:d00d15a1f2="Anthony.Baca1"]Transmission problem
2001 Dodge Caravan 6 cyl Front Wheel Drive Automatic 155000 miles
My vehicle will not shift out of gear going down the road. I have replaced the input and output sensors, I also changed the filter and fluid but is still does not shift. reverse and drive work fine.[/quote:d00d15a1f2]
you must have check engine light
check for tranny codes
most common is
Solenoid pack on side of tranny
its wiring or the TCM
I would check or replace the solenoid pack 1st
Jan 8, 2008 at 8:36 AM
