2001 Dodge Caravan
LOWKEE
  • 47 POSTS
Engine Mechanical problem
2001 Dodge Caravan 4 cyl Front Wheel Drive Automatic
i have just changed a broken timing belt on this dodge caravan. i have the timing marks lined up perfectly according to the chilton manual. however, it idles rough and when you press on the gas peddle it starts backfiring through the throttle body. it also seems to have no power when you hit the gas. i did not drive it. i also had to replace the fuel filter. please help
Oct 13, 2010 at 7:04 AM
DOCFIXIT
  • 18,828 POSTS
Check compression most likely have a bent valve
Oct 13, 2010 at 7:22 AM
LOWKEE
  • 47 POSTS
what should the compression be?
Oct 13, 2010 at 7:25 AM
DOCFIXIT
  • 18,828 POSTS
engine is interference type when T belt brakes pistons contact valves. @ 150psi
Oct 13, 2010 at 7:38 AM
LOWKEE
  • 47 POSTS
checked compression about 170 +/- 5 for each piston.
checked all wires and plugs plus coil pack. have fuel to rail and good pressure at the rail 42 lbs.
no coeds coming up as of yet. please help.
Oct 17, 2010 at 2:41 PM
DOCFIXIT
  • 18,828 POSTS
Does Chiltons marks look like these NOTE fig.5 for crank fig.7 shows cams one tooth off which is correct.
Oct 18, 2010 at 5:31 AM
LOWKEE
  • 47 POSTS
all is working i had the tooth 1 off. it was a pain trying to get the marks aligned. but everything is working good.
this vehicle must have a over rev limiter. when sitting in the driveway the car sounded like it was miss firing. but when in gear it would run normal.
Nov 7, 2010 at 4:35 AM
DOCFIXIT
  • 18,828 POSTS
Great news thanks for letting me know
Happy Motoring
Nov 8, 2010 at 3:08 AM
LOWKEE
  • 47 POSTS
thank you for all your help.
Nov 8, 2010 at 5:32 AM
