want help to change the drive belt.cant reach the belt from top.should i go under the car or take the right wheel off aand try from there.
Oct 7, 2010 at 1:13 AM
JDL
✓Experienced Mechanic
The procedure may be different depending on the litre size of engine. Litre size please?
Oct 7, 2010 at 2:15 AM
JDL
For the 3.3, my info says to put the vehicle on a hoist. If you want to safely raise and support the vehicle, that is fine. Also, removing the right front tire may let you see better.
