2001 Dodge Caravan
JASON76
Heater problem
2001 Dodge Caravan
With heater on , driver's side heat blows out just fine but passenger side is cold. The van has seperate controls for driver and passenger but passenger also includes back air and its hot too just front passenger air is cold. Hope you can help.
Feb 25, 2010 at 11:26 PM
  • 110,251 POSTS
I think you are looking for a vacuum leak in this case. The vent doors are actuated by vacuum. If there is a leak, the heat may not get directed to all locations. Check under the dash for leaks and check the linkage going to the actuators to make sure nothing is disconnected.
Let me know what you find.
Mar 3, 2010 at 2:42 PM
