2001 Dodge Caravan
CYANNOS
Electrical problem
2001 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Radio tends to go on and off for intervals ranging from 5 seconds to 5 minutes.
Also the heater blows cold and hot even though the temp gauge shows normal temperature.
Someone suggested a controller . Any suggestions?
Dec 29, 2009 at 12:51 AM
  • 110,248 POSTS
The most common problem with the radios in these vehicles is the on / off switch going bad (soder joint) The only way to repair them is to remove the radio, disassemble it, and repair the joint.
As far as the heat, it sounds like you are low on engine coolant. Have you checked that? Let me know.
Dec 31, 2009 at 9:47 AM
