2001 Dodge Caravan
180,000 MILES • 6 CYL • FWD • AUTOMATIC
SKAMPHUIS
I have a Dogde 2001 grande caravan. When I am on bright the left hand light is on, while the right side is off. When on low beam the right side lights, while the left is off. I changed the bulbs as well as the sitch in the steering column. I also replaced the relay. What else could it be?
Oct 29, 2009 at 4:50 AM
BMRFIXIT
  • 19,053 POSTS
Check for a bad ground wire
its in the wiring
check the wiring harness
Oct 29, 2009 at 12:32 PM
