2001 Dodge Caravan
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
MORONI14
I am having problem with my engine, I put the scaner tool and it game two codes one it was P0107 and it say that is the map sensor that is why i change it but still the same it shake, it have black smoke coming out from the muffler, we did everything what the mechanic have on hand but the car it still the same.
What else can I try to bring my car as before any tip will be appreciated,
Sep 18, 2009 at 4:41 PM
CH112063
  • 1,320 POSTS
Too much fuel causes black smoke, ruins the plugs, ruins the o2 sensors, ruins the catalytic converter, and needs to be tested with a DRBIII scan tool to moniter the fuel system. The other code may also be a big clue. A dealer will test reset and moniter all the inputs, outputs, codes, and reset. The fuel pressure may be off. After repair it takes a long time to rid the fuel filled exhaust to clear it up. OK
Sep 20, 2009 at 12:38 PM
