2001 Dodge Caravan
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
LRO8FL
I have a 2001 Dodge Carvan and the dash board lights has went out, I went to go check the fuse but only fuse box I see is under the hood, and I dont know what it would be under. If it's not a fuse how do I change it, and locate, where it's spouse to be fix. Thank you
Feb 15, 2009 at 1:08 AM
  • 110,248 POSTS
Hi:
There should be a fuse box under the dash on the driver's side or on the bottom of the dash (left side).
Do you still have an owner's manual for it?
Feb 18, 2009 at 11:26 AM
