2001 Dodge Caravan
DJCCLF
2001 Dodge Caravan 4 cyl Two Wheel Drive Automatic
what steps do i need to do to replace a broken wheel stud on front axle
Oct 25, 2008 at 12:27 PM
  • 110,248 POSTS
Hi:
You will need to remove the wheel, caliper, rotor, and using a punch, pound out the broken stud and replace it with a new one. Reverse order for reassembly.
NOTE: Make sure when you replace it that it is pulled through the entire way, otherwise it will work itself loose.
If you have any other questions, let me know.
Oct 27, 2008 at 3:30 PM
