i have done all that and i have i am how looking at the ignition switch relay 30 red wire and the 87 yellow wire when i checked the red wire with a test light it dos not come on but when i check it with avoltmeter it shows to have 12v coming to it. but when i turn the key to the start the red wire losses all power. so would this be a short in the ignition switch and i need to replace it right.
[quote:98dc3e0be3="jdl123"]When the starter refuses to crank, have you tried cranking in neutral? If you have voltage at two of the relay terminals, key in crank position, check the ground for the coil side of relay,85, according to my info. The computer grounds that circuit. If there is no ground there are other issues that could cause that besides the pcm.
I have no idea why the seatbelt switch is involved. I even thought about unplugging that switch or bypassing.
If you could check for P and U codes. It might point you in the right direction?[/quote:98dc3e0be3]
Apr 16, 2009 at 7:47 AM
