2000 dodge grand caravan back windows fogging up
TLA258
  • 10 POSTS
i am working on a 2000 dodge caravan with a 3.3 in it. my problem is the back windows fog up like as if the heater core is leaking i checked both cores no indication of any leaks and i dont smell any anti freeze does antone have any advice on this thank you
Mar 6, 2007 at 9:52 AM
VAMPYRICO
  • 27 POSTS
do you have a rear window defroster?
Mar 9, 2007 at 1:12 PM
TLA258
  • 10 POSTS
yes\
Mar 10, 2007 at 6:08 AM
VAMPYRICO
  • 27 POSTS
if thats not functioning, check the fuse for it. if the fuse is good, inspect the lines on your back window for chips and general breaks in the line. if thats there are, thats why the defroster doesnt work. best i can tell you is to get that rear defroster up and running. if its the breaks in the wires. then it would have to be redone.
Mar 10, 2007 at 3:48 PM
