2000 Dodge Caravan won't change gears after transaxleand or
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARPETGUY
My caravan works fine until the engine and or the transmission heats up, then it stops shifting into the drive gears IE, 3rd, 4th,i replaced both speed sensors,the transmission Module,blew out the cooling(fluid) radiator. but, once the van warms up, it stops shifting, causing the engine to high tach,
Aug 27, 2010 at 10:41 AM
  • 110,248 POSTS
Has the check engine light come on? Have you checked shift solenoids?
Aug 27, 2010 at 5:53 PM
