2000 Dodge Caravan vibration
107,000 MILES • 6 CYL • FWD • AUTOMATIC
GIBSRACIN
i just put new drums on the rear since i have already had the old ones turned and would probably be out of spec and i have a bad vibration at high speed braking.
Sep 3, 2009 at 6:16 AM
CH112063
  • 1,320 POSTS
Most of the time the front rotors cause high speed vibration whilr braking. To tell the difference at high speed apply just the parking brake whilr holding the release lever if possible or just apply them and see if the problem is only from braking in the rear. If the rear wheels are ok and not loose and the tires are ok, then the problem is the drums or the shoes.
Feb 21, 2021 at 5:27 AM
