I drive a 2000 Dodge Caravan. 141,000 miles. Tranny has leaked fluid (ONLY during cold weather) for years, but is not a problem during summer. I always keep fluid topped off. Anyway, the past 2 weeks it will suddenly get stuck in FIRST gear only and will not upshift. Then I cant use interstate. If I park it for a little bit (go into a store, whatever), then its fine again and I can go interstate...until the next time it happens, usually sometime the next day or two...Its happened about 6 times now. Never happens while driving 60 MPH. Every time it happens, its around town while doing 35-45MPH. Fluid level is good, clear, clean, and not burnt smelling.
I have not taken it to a shop yet, because I KNOW they WILL tell me I need a new transmission, and I think its probably NOT the case...Could it be the control module? What do you think it likely is? Thank you very, very much.
May 10, 2006 at 3:58 PM
