2000 Dodge Caravan Transmission Stuck in 1st?
JOHNROSE7
I drive a 2000 Dodge Caravan. 141,000 miles. Tranny has leaked fluid (ONLY during cold weather) for years, but is not a problem during summer. I always keep fluid topped off. Anyway, the past 2 weeks it will suddenly get stuck in FIRST gear only and will not upshift. Then I cant use interstate. If I park it for a little bit (go into a store, whatever), then its fine again and I can go interstate...until the next time it happens, usually sometime the next day or two...Its happened about 6 times now. Never happens while driving 60 MPH. Every time it happens, its around town while doing 35-45MPH. Fluid level is good, clear, clean, and not burnt smelling.
I have not taken it to a shop yet, because I KNOW they WILL tell me I need a new transmission, and I think its probably NOT the case...Could it be the control module? What do you think it likely is? Thank you very, very much.
May 10, 2006 at 3:58 PM
JOHNROSE7
Today I put my little OBD-2 reader ($60 Walmart) on and got one code, P0700. Research of this code generally has comments that the TCM (Transmission Control Modul), or rather PCM, needs to be replaced. Since this is about a $200 deal, I would like to know if this sounds like a good, secure diagnoses before I spend the money. If I need a rebuilt transmission anyway, I would rather save this $200. Thanks for ANY input or comments...
May 11, 2006 at 12:30 AM
ZASIMOM
[quote:171b66a3db="Johnrose7"]Today I put my little OBD-2 reader ($60 Walmart) on and got one code, P0700. Research of this code generally has comments that the TCM (Transmission Control Modul), or rather PCM, needs to be replaced. Since this is about a $200 deal, I would like to know if this sounds like a good, secure diagnoses before I spend the money. If I need a rebuilt transmission anyway, I would rather save this $200. Thanks for ANY input or comments...[/quote:171b66a3db]I was wondering if you were able to fix your problem? The reason I asked is because my 2002 Dodge Intrepid has the same code. My car works fine until I have to slow down and then it seems to get stuck in gear (I've heard it called limp mode). If I stop the car and restart it, it will work fine until I slow back down again. Thanks.
Sep 14, 2006 at 6:40 AM
