2000 Dodge Caravan transmission leak
JKARKLUS
  • 2000 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 61,000 MILES
My transmission is leaking. A mechanic said it is leaking from the front near the control box. It is not a bad leak, and I have noticed no problem from it. Is this serious.
Friday, December 19th, 2008 AT 9:47 AM
  • 109,885 POSTS
Hi:
did he tell you where the leakis coming from? Is the pan leaking?
Friday, December 19th, 2008 AT 11:42 PM
JKARKLUS
He said it was leaking under the hood behind the radiator where the control box is.
Saturday, December 20th, 2008 AT 8:32 AM
  • 109,885 POSTS
That is really vague for me to pinpoint. What I suggest is to try to clean everything off (car wash) and see if that helps identify the problem. Most likely it's the trans pan, but I can't be sure without more info.
Let me know if you can do this or if it helps.
Saturday, December 20th, 2008 AT 1:42 PM
