fluid leakage
118,000 MILES • 6 CYL • FWD • AUTOMATIC
PRAJUL1995
Recently I had replaced two rubber hoses that go to the transmission oil cooler, but the leakage continues. What else can be leaking? If it is transmission oil gasket on the pan how much is a reasonable amount to pay to repair it?
thank you.
Jan 2, 2010 at 4:32 AM
CH112063
  • 1,320 POSTS
If it is still leaking try and determine the location. Try and check it while running with the parking brake on, in Nuetral, not Park, I want you to do it safely, and see where it pools up, ok? make sure there is fluid in it before you start. ok? which engine do you have? And do you have the OD transaxle? It may not be the pan, if it is you may as well do a service which includes a filter and gasket also. It should be less than 125 ok? The area, the gear selection and the amount and powertrain type are important, good luck, your welcome, anytime. Thank these men who set everything up, ok?
May 21, 2021 at 7:58 AM
TRANSMAN1
  • 29 POSTS
If you have the overdrive trans look very closely where the solenoid pack meets the transmission case in the front by the bell housing .Solenoid gaskets leak and then run around the trans pan edge and make it look like pan gasket is leaking.
