2000 Dodge Caravan Transmission Does not engage
2000 DODGE CARAVAN
104,000 MILES • 6 CYL • FWD • AUTOMATIC
BRTSY1
My Dodge Caravan transmission doesn't always engage into drive whenyou first try driving. Reverse seems to be ok. Seems to be an intermitant problem.
Oct 24, 2008 at 4:27 PM
MASTERTECHTIM
  • 4,750 POSTS
unfortunately thats a tell tale sign of a trnamission internal problem. you may want to have a transmission shop take it for a ride and check the computor for a transmission trouble code, its also possible if there are codes stored that it may only be a transmission input and or output sensor which are inexpensive but you need to check for codes first. hope this helps
Oct 24, 2008 at 10:19 PM
