2000 Dodge Caravan Timing Belt
63,000 MILES • 4 CYL • FWD • AUTOMATIC
P. CORREA
I have a Dodge Caravan 2000 with 63,000 miles and runs fine. However, the dealer mechanic told me I should change my timing belt and water pump. To change the timing belt will be $800. For a separate charge, if I do their 60,000 mile maintenance check, for $545, it will include the replacement of the water pump for a total of about $1300+.
Does this sound reasonable to you?
Jun 24, 2008 at 4:20 AM
LEGITIMATE007
  • 5,121 POSTS
I guess, the water pump if it is inside the timing cover then It should be done while doing the belt, but should cost too much more than just the timing belt
Jun 26, 2008 at 8:38 AM
