I replaced TPS sensor and still have same problem with the car bucking at excelleration
Oct 24, 2008 at 11:34 AM
MASTERTECHTIM
✓Experienced Mechanic
have you replaced the spark plugs and plug wires? is the check engine light on? any codes?
Oct 24, 2008 at 11:37 AM
BILBIL
MEMBER
yes the one for the TPS sensor
Oct 24, 2008 at 11:47 AM
MASTERTECHTIM
if you already replaced the tps then i would double check the connector to it. lightly pull on wires to make sure one is not broken inside the insualtion. next step after that is to watch voltages on a scan tool.
