2000 Dodge Caravan tcm
2000 DODGE CARAVAN
GGDAD
Transmission problem
2000 Dodge Caravan 6 cyl Two Wheel Drive Automatic
can you tell me where the tcm is located on my van. i started it up this morning and the shift indicator is all squares and the is no indicator movement. does not seem to be shifting right. thanks
Jun 23, 2010 at 4:29 AM
  • 110,240 POSTS
If you are at the front of the vehicle, craw under it to the transmission pan. The TCM is located right above the pan (in the front). It is a black box. The section connected to the trans is aluminum and the cover that you will see first is black plastic.
Let me know if you can't find it.
Jun 23, 2010 at 2:45 PM
