2000 Dodge Caravan switch
YENG_337
  • 2000 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 198,000 MILES
Hey guys I got some issues with my van. When I turn on a/c or heater nothing happens no air but if I turn it on all the way up than it turns on. What could be causing this
Thursday, December 3rd, 2009 AT 8:15 AM
CARADIODOC
  • 33,873 POSTS
I assume you mean the fan only runs on the highest setting. If that's correct, the internal thermal fuse in the resistor block is burned out. Most of the time replacement of the resistor assembly is all that's needed. If it burns out again in a few months, suspect the fan motor is getting tight causing it to draw excessive current.
Caradiodoc
Friday, December 4th, 2009 AT 4:02 AM
