2000 Dodge Caravan Starting problem
168,000 MILES • 4 CYL • 2WD • AUTOMATIC
DBROWNE57
My 2000 Dodge Caravan 168K has trouble starting. It takes 3-4 attempts for the van to start. Doesn't crank right up when I put the key into the ignition. I get a click sound when I turn the key. Everything comes on. Radio, lights, etc.. Will start right up after the 3rd to 4th try.
Feb 10, 2010 at 12:37 AM
JDL
  • 16,098 POSTS
Welcome to the forum. When the problem occurs, check voltage circuits at starter relay. Terminal 30 is hot all the time, terminal 86 goes hot with the key in the crank position. Can't rule out security system, the computer grounds coil side of relay.
You need to make sure the battery has a full charge and the connections are good.
Oct 23, 2019 at 7:48 AM
