2000 Dodge Caravan starter
RNEWBY451
  • 2000 DODGE CARAVAN
Engine Mechanical problem
2000 Dodge Caravan 6 cyl Front Wheel Drive Automatic
eng will not start when the key is in the start postion it take about 4 try and the enger will start after the car has run for a while you can cut the car off and it will restart on the second tryi
Sunday, September 27th, 2009 AT 2:55 PM
CH112063
  • 1,320 POSTS
If it starts ok in neutral and not in park the neutral safety switch or valvebody or connector could be bad. If not the starter solenoid on the starter, the relay, connectors, ign. Switch. In that order. I think its the starter or a connection problem. A remote starter can be used to check it. Ok
Monday, September 28th, 2009 AT 8:52 PM
