2000 Dodge Caravan Solenoid Replacement
123,500 MILES • 6 CYL • FWD • AUTOMATIC
LEAHFRAZIER
How do I replace my solenoid? The van sometimes starts on the first try otherwised I have to click the key on and off a couple of times before it will start. We are thinking it needs a new solenoid.
Oct 27, 2008 at 7:24 AM
BMRFIXIT
  • 19,053 POSTS
If you mean starter solenoid ,
its a part of the starter
check the small wire at the starter solenoid make sure in clean and tight
if all OK suspect a bad starter
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 27, 2008 at 2:23 PM
