2000 Dodge Caravan Remote
MCEAGLE2K
Electrical problem
2000 Dodge Caravan 6 cyl Front Wheel Drive Automatic
how can i re-program additional remote for my DODGE CARAVAN SE 2000 Model v6 3.0 L?
Feb 8, 2009 at 3:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Most keyless entry remotes come with programming instructions. If your remote didn't come with one, you can contact your local Dodge dealer or locksmith to ask for a printout of the instructions. A common programming procedure for a keyless entry remote is below..
Step 1: Open driver side door and leave open.
Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
Step 3: Insert key into the ignition.
Step 4: Turn Key to ON position and return to Lock (off) position. Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
Step 5: Close and open the drivers door 3 times. Leave door open after this step
Step 6: ECU should respond by locking and unlocking the doors once.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks.
If these steps do not program your remote, just contact local dealer or locksmith for your specific vehicle's programming instructions..
Thanks for using 2CarPros.com!
Feb 8, 2009 at 9:07 PM
