2000 Dodge Caravan Passanger side brake light
TED CROWDER
I changed the bulb and the brake light is still out. The tail light it self works fine and all other brake lights work.
Dec 2, 2008 at 10:08 AM
ZACKMAN
  • 4,202 POSTS
Switch the bulb with the good bulb from the driver side. If it still doesn't work, it is wiring problem. It will require someone to physically check the brake light wire from the socket (I could be the socket is bad, too), to where all the brake wires are connected.
Feb 27, 2021 at 5:52 AM
