2000 Dodge Caravan OVER HEATING
136 MILES • 4 CYL • 2WD • AUTOMATIC
RPERRY31
It all started with the coolant fans constantly running after the ignition was killed and would never shut off.I got heat sensor, check the relays.The fans still would not shut off.I would have to pull off the batteries to get the fans to stop when parking.All of a sudden the fans shut off when I shut off the car.Now though when you turn on the air conditioning the car over heats.What should i can't afford to take it to the shop but I diffently need my van for work.Could someone help me
Aug 24, 2008 at 9:43 AM
MASTERTECHTIM
  • 4,750 POSTS
replace the cooling fan relay and all of your problems will be gone. hope this helps
Aug 24, 2008 at 10:28 AM
