2000 Dodge Caravan o2 sensor replacement problem
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRIS ALBERT
have replaced o2 sensor (before catalytic) and still getting engine code that is it not connected---used a denso oem---told it would work fine---is this a wire harness problem and if so , where can i get a new wire harness ????
Apr 11, 2010 at 11:48 AM
CH112063
  • 1,320 POSTS
Either you must relearn the computer or there is something wrong with the wiring or ground(behind the left cylinder head). I am just guessing it's a 3.3L but either way you must use a scan tool to reprogramm the PCM. It must be done when replacing parts. I know it's a pain but it will give you a chance to check if there are other codes also.
Apr 11, 2010 at 4:51 PM
