2000 Dodge Caravan Not sure what the problem is
13,000 MILES • 4 CYL • 2WD • AUTOMATIC
DDHAMBLIN
I think my tranny is going out. When I hit the gas, esp when going up a hill or getting on the freeway it acts like it doesnt want to go like it almost stalls and shakes when I hit the gas. Im not sure what is causing this. I had some kid change my spark plugs a while ago and thats kind of when I noticed it all happening. I cant really afford to get it fixed so im hoping its something easy. It is just really weird iv never felt that when hitting the gas before its like i floor it and it shakes and doesnt really seem to go anywhere then finally catches on and goes. any Advice please =)
Jul 10, 2010 at 7:36 PM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 10, 2010 at 8:25 PM
