2000 Dodge Caravan noise when heater in on
289,000 MILES • 6 CYL • FWD • AUTOMATIC
MANOK
  • 8 POSTS
hello bob and ken,
this is with regards to the noise that i hear everytime the heater is turned on. the noise is coming in the center or cabin behind the radio and in the glovebox. i tried to turn the selector switch and the noise comes off only on the winshield defogger. what must be the problem? and i another question with the same vehicle. the check engine went on and the code is P420. is it the oxygen sensor or the MAP sensor? hope to hear from you and thanks again for the great help you are providing us.
Dec 3, 2008 at 8:06 AM
  • 110,246 POSTS
Hi:
A PO420 code is relating to the cat converter. Something is wrong there. Also, the noise you described seems to deal with the blower motor. IT's located inder the dash behind the glove box. Is it a squealing sound? However if it's the motor it shouldn't matter what direction the air is going. You may have something in the duct work that moves when you open the defroster door.
Dec 5, 2008 at 7:17 AM
